Shows the operational status of Integrated Application Hosting (IAH) guest virtual machines (VMs).
| vm | Designates a virtual machine. |
| vm_name | Specifies the VM name to add show information about. |
| detail | Specifies showing detailed information. |
N/A.
The IAH feature requires the Solid State Storage Device SSD-120.
The following example shows information for VM "TPVM":
# show vm TPVM
VM Name: TPVM
State: Running
Memory size: 4096 MB
CPUs: 2
Auto-start: Enabled
VNC: 127.0.0.1:2 (Port 5902)
Disk: vda
Source: /mnt/vmstorage/TPVM/TPVM.img
Disk bus type: virtio
Allocated size in bytes: 34359738368 (32.00 GB)
Physical size in bytes: 4199288832 (3.91 GB)
Read requests: 15947
Bytes read: 349533184
Write requests: 330
Bytes written: 4293632
Network interfaces:
Attached switch ports: 33-34
CPU utilization:
User: 10.00%
System: 30.00%
Memory utilization:
Used: 0.05 GB
Available: 3.95 GB
The following example shows information for multiple VMs:
# show vm
S A Name |--Memory (GB)--| |----CPU-----| Ports
Total Used Avail # Sys% User%
* E TPVM 4.00 0.05 3.95 2 10.00 30.00 33,34,Mgmt
D tpvm2 4.00 N/A N/A 2 N/A N/A None
Status: (*) Running
Auto-start: (D) Disabled, (E) Enabled.
This command was first available in ExtremeXOS 30.3.
Clarifications were made to memory and CPU usage information in ExtremeXOS 30.5.
Disk bus type information was added in ExtremeXOS 30.7.
This command is available on all platforms that support the Integrated Application Hosting (IAH) feature and have a Core or Premier license installed. For a list of platforms that support the IAH feature and for information about licenses, see the Switch Engine v33.1.1 Licensing Guide .
